0
Originally Posted by
progmgr1
If I understand the photo correctly, it looks like the weight of the engine (x3 or x4 to account for vibration) is being carried by a single bolt loaded in both shear and bending. Are you using a shoulder bolt for this and did you use a larger size bolt than usual? If the answer to either question is "No", then I would be concerned about the bolt failing in a relatively short time - with possibly terrible consequences.
Keith HR #894 (& BSME/MSME)
1/2" grade 8 and there are 2 bolts to the frame, one that bolts the mount to the mount, 3 in to the block.
