0
0
FFR 65 Cobra turn signal wiring MK#3 with donar 96 mustang wiring
I'm chasing some wiring gremlins from the previous builder specifically the indicator lights and the VW turn signal switch arm I have
Please explain where each wire goes on the attached diagram. do I run a ground to the right and left dash indicator lights and then tie them into the main ground circuit?
- You may not post replies
- You may not edit your posts
Forum Rules
