Results 1 to 2 of 2
Thread: Engine mount 35 Hot Rod Truck
    Apr 2024
    Not sure what to order
    I want to install a 94-95 Mustang 5.0 in the 35 Hot Rod Truck.
    Do I choose the 302 or the Coyote 5.0 from the build sheet?
    Thanks, Charlie
    Falmouth, MA
    I believe you would choose the 302 as that is the same engine series. The 5.0 is actually the 302 engine (61 c.i./liter approximately). The coyote is an entirely different engine series. When you place your actual order with FFR they will review and correct any errors in your thinking for the proper mounts, driveshaft, etc.
  3. Thanks scspeedster thanked for this post
