Results 1 to 3 of 3
Thread: Oil dipstick install
    Dec 2023
    Getting the entire engine in the roadster was way faster than getting the oil dip stick in the hole.
    I have seen people have a similar issue but not clear on how it was resolved.
    I can't get the dipstick past the first ring.
    Looks like it should go in further but no luck so far.
    This is a blueprint 302 engine.
    Suggestions?
    Mk IV, IRS, 302 w/EFI & T5, 15" wheels
    Dublin, OH
    it's a press fit. try putting an adjustable wrench above the flare in the tube and tap on the wrench with a hammer. taking the paint off with a wire wheel or sandpaper can also buy you some clearance. a little grease may help too.
    May 2022
    Fishers, Indiana
    I had the same issue . I had to file the all the paint off and some more before it would go in.
