0
0
Coupe Clutch Pedal Fix
Here is what I did to get a full clutch pedal travel. I used 3/8" 6061 T6 Alum. cut to the shape of the org. Wilwood new forged part. The pedal with a reduced width now does not contact the 3/4 sq. tube. I used 1/2" 6061 T6 on the bottom to increase width width to mount Wilwood adjustable pedal pads. The top mount for the cable arm has 2x's the material. Paint to match , add space and I am moving on !
Pedal 2 013.JPGPedal 2 014.JPGPedal 2 015.JPGPedal 2 016.JPGPedal 2 016.JPGPedal 2 017.JPGPedal 2 020.JPG
Nice fab job on this problem, thanks for shareing this with us!!
- You may not post replies
- You may not edit your posts
Forum Rules
