Results 1 to 2 of 2
Thread: New to Forum.MK4 build with Coyote engine-Fuel install questions
    Jul 2024
    I am trying to build an MK4 and having some issues. I am new to the forum and not exactly sure how this works but I am needing some help and was hoping I could find it here.
    I am trying to install the fuel system, tank, lines, filter, etc. The instructions for installing the fuel filter doesn't work as I read it. There is no way of mounting the fuel filters to the frame without kinking the feed line.
    Can you help me figure that out?
    Also, what is the value of the fuel return line on this system?
    Thank you for your help.
    Norton, MA USA earth
    You can mount the filter wherever you want it. You will just need to make a longer line. Its a pretty open system once you wrap your mind around it. I buy all new lines and fitting on Amazon and start from scratch. you will need a return line for any EFI engine.
  3. Thanks deanmyers thanked for this post
