0
0
Hi Alan,
That's correct - you should just be able to transfer those holes through from the cockpit side into the aluminum. Also just wanted to confirm that the master cylinder/hydroboost assembly will indeed be slightly rotated toward the engine in order to allow the reservoir to be filled.
I think you'll really like power brakes on your car!!
Jason @ FFR
