Thread: ? FFR Coolant Overflow Tank on '98 SOHC Roadster?
    Junior Member FFR-HamptonVa's Avatar
    Hampton, VA USA
    https://factoryfiveparts.com/product...cat=256&page=2
    My Overflow / Reservior was damaged in the donor & wondering if I can simply replace with the FFR unit at the link provided?
    Does the Radiator Cap fit this or do I need a diffenent unit not offered by FFR?
    FFR Tech Support
    The donor 4.6L cooling system needs the stock overflow tank unless you install an inline filler in the upper radiator hose.
    Hampton, VA USA
    Andy,
    Thanks for the reply & info. My donor Expansion Tank tabs were broken so I am looking for a replacement. I am considering a couple of other options based on Forum Member input.
    Thanks again for the clarification.
    Blue Oval Scribe Mustang Man's Avatar
    Lakeland, FL
    Both Moroso and Canton make aluminum direct-fit replacements for the '94-'09 Mustangs...
    HTH...
    Mark
    Modified Mustangs & Fords Project Snake Charmer
    FFR5310 Mk 3 Roadster
    Tungsten Gray/Silver Stripes
