MUST SEE --- A GREAT DONER CAR --- This car was to be a track car but time and money have made that impossible. I'M SELLING BECAUSE I NEED THE MONEY. --
This car is located in Amity, OR; about 30 minutes north of Salem.
The suspension has been completely replaced with after market equipment, the bulk of it being from Maximum Motorsports and is fully adjustable. -- Rebuilt engine down to bare block; new rings, seals, valve job & paint. The drive line has been replaced with a Tremek TKO transmission, Ford Motor Sport aluminum drive shaft, 3.50:1 diff gears mated to a Torsen T-2 torque biasing differential.
--- THE CHASSIS HAS 91,462 ORIGINAL MILES; THE DRIVE TRAIN HAS ABOUT 7,000 MILES, AND THE ENGINE HAS 2,000 MILES. ---
1989 5.0 Mustang LX Hatchback
Auto Meter Gauges: Oil pressure, oil temp., water temp.
Jacobs ignition: 5.0 Ultra Team '87-95 Mustang
MSD Billet distributor
MSD 8.5mm ignition wires
BBK shorty headers
Weiand high flow water pump - chrome
Edelbrock exhaust - 2 ½"
Fluidyne 2-row Aluminum Radiator
A/C eliminator bracket
battery relocated behind passenger seat
140 amp alternator
Cobra R 5-spoke 17" wheels - 5 lug
'95 Mustang front spindles - for 5 lug wheels
Kumo 245-45-17 tires
Brembo 13" front disc brakes, Hawk brake pads
PBR caliper, 12" Power Slot rear discs
Brake proportioning valve - located in engine compartment
Steal braided brake lines
Koni Sport Double adjustable front struts - bump & rebound adjustable
Koni Sport Double adjustable rear shocks - bump & rebound adjustable
Hypercoil coil over springs 2 ½ dia. 400lb/in front and rear
Maximum Motor Sports Full Length Subframe connectors
Maximum Motor Sports Strut Tower Brace
Maximum Motor Sports 4-point k-Brace
Maximum Motor Sports Torque Arm
Maximum Motor Sports Panhard bar
Maximum Motor Sports Adjustable Rear Swaybar
Maximum Motor Sports Adjustable Height Rear Control Arms
Maximum Motor Sports Front Coil-Over Kit - adjustable height
Maximum Motor Sports Caster/Camber Plates
Baer Bump Steer Adjustable Tie Rods
Flaming River Steering Shaft
Maximum Motor Sports aluminum Steering Rack Bushings
Rebuilt ford steering rack
Tremec TKO 5-speed transmission. 31 spline output shaft
Ford Motor Sports 3.50:1 diff. gears
Moser Engineering 31 spline axles
Straightened axle housing
T-5 Steel Bearing Retainer (replacing the factory aluminum retainer)
Solid Transmission Mount
Ford Motor Sports Aluminum drive shaft (straightened and balanced)
Ford Motor Sports King Cobra clutch
McLeod friction plate
Summit Racing adjustable clutch cable
Summit Racing aluminum clutch quadrant
Momo sued wrapped steering with quick release.
Low Jack recovery system (will need new battery and to be check by technician).
E-mail me [email protected] or call at 503 835-0585
