Thread: Coupe Winter Mods
    Coupe Winter Mods
    Many thanks to Gary Jones, good friend and master mechanic, for seeing to a lot of little mods that have been on the back burner for some time:
    1. Russ Thompson pontoon stiffeners.
    2. Russ Thompson "Daytona" script aluminum door sills.
    3. Russ Thompson scoop window "block-off" kit.
    4. Replaced both scoop windows ... original ones broken/cracked.
    5. Installed remote filter and oil cooler.
    6. Rehung both doors ... both were "sagging" and hard to open/close.
    7. Replaced rear hubs/bearings and installed HD axle/CV joints from The Drive Shaft Shop.
    Including a few pics:
    Senior Member Mike N's Avatar
    Mooresville NC
    Hadn't seen those pontoon stiffeners before they look great with the rolled edge lightening holes. Very cool.
    Mike............
    Mike,
    Just another quality product from Russ Thompson ...
    Mark Dougherty's Avatar
    Hershey PA
    Wow Gary
    those stiffeners are awesome
    The traveling Builder
    717-773-5624
    Northern CA
    Garry,
    Just more things that Russ brings to the table, great products and Ideas
    Hank
    Quote Originally Posted by Mark Dougherty View Post
    Wow Gary
    Plus they cover up an area of unfinished fiberglass on my coupe!!
