The Mendeola works great. See here...
http://www.youtube.com/watch?v=YCrbHt7Ln-Y
Who uses PPG gears? Generally speaking, people who own cars that make very significant amounts of power. PPG makes some amazing gear sets, but they still have to work with the design of the 5-speed case. They've beefed up that unsupported section, but when you increase the power proportional to the increased capability of the gear sets, you're effectively right back where you started, and in some cases (i.e. retaining the stock 5th gear), you're worse off.
Think of it this way: if at low power levels (300whp or less), the transmission case flexes enough to inflict damage upon the gears, what do you think it would do if you doubled the amount of power going through it? People using PPG gear sets and making over 500whp would be leaving massive chunks of transmission case on the track. Case flex is not unaffected by power output, yet those people making 600+whp with built 5-speeds have zero issues with case breakage.
The input shaft, by design, is the weak link. It will flex first, and when it does, there's nowhere near enough force left over to affect the case.
'03 WRX, soon to be broken I'm sure
