Hi John,
Looking at the strings running along the door, and cant tell how high they are. Did you check if the seat is going to fit in the passenger side? In my car on the passenger side I had less than a 1/4 in. clearance between the seat and the door and the tunel panel. I made a new tunel panel and gained almost 2 in.,it allowed me to move the seat to the center so that I could operate the power seat switch on the side of the seat. It may give you the room you need to run that tube and be able to fit your seat.
Good point Mike. I have not tested the passenger seat honestly. The lower bar is under the widest part of the seat so I was guessing that it would be fine. Im surely going to check it out. Thanks for the tip.
XTF #2
build start date June 19 2023
GTM # 344
Build Start December 2010
First track day April 2013
