Results 1 to 3 of 3
Thread: EFI wirers?
    Junior Member BULLITT428's Avatar
    North Vancouver Canada
    EFI wirers?
    I'm running a carb not an EFI and I have an AL-6 MSD box and a MSD distributor. I have two wires with the Ron Francis wiring harness orange and blue that are for an EFI. Should I run the orange one to the coil or is this necessary.
    Thanks ED.
    FFR 7570, 402sr ROUSH 455HP, TKO 5 speed, Wilwood brakes, IRS 327gears Torsen Diff, Forte's Hydraulic Clutch, 15to1 AGR Power steering rack and lots more it never seems to end?
    TEMPTATION: because willpower is no match for Horsepower!
    The orange wire in the RF EFI bundle is simply a switched 12v wire. If you need one for your MSD components or coil, use it or use it for any other 12v switched need.
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
  3. Thanks BULLITT428 thanked for this post
    Jun 2015
    Fairfax Station VA
    Light blue wire is +12V ONLY at ignition. Good for triggering a latching relay, but generally not used for carb.
    MK IV Roadster #8631
