Results 1 to 10 of 10
Thread: help!! how am i gonna polish all this aluminum?
Hybrid View
    Todd missouri rodder's Avatar
    Sep 2011
    Columbia, Missouri
    Would really appreciate some expertise in the easiest way to polish and protect all this aluminum? Wouldnt the firewall look great if it were all in machine turns? anybody got an easy way to do this? I hate dull aluminum.
    The firewall is pretty much the only aluminum you will see once the car is assembled. Assuming your are going to carpet the interior and trunk. One of my customers did the engine turn thing on his firewall. Looks good. He had a clear coat put on after.
    Senior Member OCCPete's Avatar
    Dayton, OH
    If you want it engine turned, Eastwood sells a kit to do it. I used this on my gauge pod and switch panel. Very easy to do, just takes some time.
    http://www.eastwood.com/ew-engine-tu...-diameter.html
    Pete
    Senior Member 1fastsedan's Avatar
    San Diego, CA
    Quote Originally Posted by missouri rodder View Post
    I'm planning on engine turning my firewall, I'll let you know how it goes in the next couple months.
    Aliso Viejo, CA
    Engine turning the firewall is awesome. Terrible Terry did it and it looks great. Must make sure you have a large enough drill press as you'll be hitting the support post if you don't. Also be sure to use the fence effectively otherwise it will be all over the place. And, oh yeah, be sure to have LOTS of time on your hands.
    Senior Member Arm7419's Avatar
    Sedona Az
    Powder coat everything and forget about it
    chuck
    Chuck
    Mk1, MK3, Hotrod, Gen 3 Daytona Coupe, RF GT40
    Hang Up and Drive
    Sep 2011
    Columbia, Missouri
    What about sharkshyde, i found at Eastwood also? How about buffing to a shine, compound and buffer, orbital or buffing wheel, tried wet sandpaper method? does is need to be polished before engine turned?
    Dayton, OH
    I polished the firewall in my roadster by wetsanding then using this amazing stuff: http://www.californiacustom.com/purp...al_polish.html
    No polishing required before engine turning.
    Pete
    Milton,DE
    Think twice about polishing the firewall. It might look good for a little while but unless it was clearcoated with a quality process it will look very tarnished and dull before too long.
    For an easy to clean, long lasting finish, either powder coat or paint. I painted mine. It is the same Brandywine Kandy as the fenders and suspension.
    Olli
    Sep 2011
    Columbia, Missouri
    thanks everybody, I am going to polish and see how well i can keep it up. I bolted, not riveted the firewall on, so i guess on final body prep/paint i could change my mind. It's terrible when the part of the build that's the most stressful is appearance of the firewall. at least so far!
