My current car is in mock-up wheels. I had to machine out the inside (hub area) of some 17 inch wheels with approximately 6 inch backspacing to fit the hub size on the front axles, just over 2 3/4 inches on my SER Number 1000327.
1. sure looks like this is going to be a problem with many aftermarked wheels? how about past builders, have issues with this?
2. my rear axles are Strange, they have 3 inch center offset, i can use small spacers to fix this. But really have problem here also.
3. I would like to run a more classic rodder deep dish look, I like the look of some E/T 5 window wheels for this type of hot rod, but they only come in 15 inch diameter, and not sure if they would fit. Almost too scared to even get the dimension sheets because i would be tempted to buy then, cause i know they are gonna be close to my calipers. Anyone running 15 inch E/T wheels on a 33HR?
4. anyone with ideas on these items?
thanks.
