Thread: Fuel Pressure – Maintaining
    Kirkland, WA
    How long should the fuel system maintain the fuel pressure? Mine goes from 40+ to 0 in less than 2-3 min after I shut engine off, seems like t should keep for a while.
    Tony Nadalin
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    818R Build in progress
    Challenge Series Director FFSpecRacer's Avatar
    some longer, some shorter. Typical.
    Brian [email protected]
    Great Lakes & Midwest Region Series Director
    Senior Member ClemsonS197's Avatar
    Marietta, GA
    Is your regulator hooked up to vacuum? Mine dropped to zero in minutes. Once I got the vacuum line connected to the regulator, it holds for days.
    MK3.1 #7076 - Under Construction....
    Coyote 5.0/Solid 8.8/Tremec 3650
    How to:
    Coyote Power Steering
    05-09 T3650 in a Roadster
    Kirkland, WA
    Quote Originally Posted by ClemsonS197 View Post
    Yes it is hooked to a vacuum line under the Trickflow manifold
    Tony Nadalin
    Senior Member Mike N's Avatar
    Mooresville NC
    It may not be the regulator that is allowing the pressure to bleed down it could be the injectors, seals or even fuel pump.
    Mike............
    Kirkland, WA
    Quote Originally Posted by Mike N View Post
    So loosing fuel pressure is not an issue? as I'm trying to figure out a engine stumbling issue that I have and noticed this
    Tony Nadalin
    Pressure bleeding off is normal when not running.
