How long should the fuel system maintain the fuel pressure? Mine goes from 40+ to 0 in less than 2-3 min after I shut engine off, seems like t should keep for a while.
Tony Nadalin
2018 SOVREN Big Bore Champion
2012 ICSCC ITE Class Champion
818R Build in progress
some longer, some shorter. Typical.
Brian [email protected]
Great Lakes & Midwest Region Series Director
Is your regulator hooked up to vacuum? Mine dropped to zero in minutes. Once I got the vacuum line connected to the regulator, it holds for days.
MK3.1 #7076 - Under Construction....
Coyote 5.0/Solid 8.8/Tremec 3650
How to:
Coyote Power Steering
05-09 T3650 in a Roadster
Tony Nadalin
It may not be the regulator that is allowing the pressure to bleed down it could be the injectors, seals or even fuel pump.
Mike............
Tony Nadalin
Pressure bleeding off is normal when not running.
