Filling the FFR tank with ease
As we all know the stock tank setup makes it really tough to fill the tank. We've done everything from moving the filler to buying a new tank. I'm no exception. Having read the woes of filling and some solutions by various members, I decided to move the filler to the outside on the bulkhead between the trunk and the back of the cockpit. This gives it a better gravitational position right away. Also, you can drill out the older tank vents at the nipple to increase venting. The newer kits are supposed to come with a larger vent which will decrease back-vapor making the pump stop. Last, but not least, buying the "McCuff" has helped me most when filling. I can fill without stopping now and it reduces spalsh-back. It can be found at www.mccuff.com and it stores underneath my seat easily.
Please share any other input or mods you may have for filling the tank.
