Has anyone incorporated jacking pads on the bottom side of the GTM Chassis?
I'm thinking that it would be a good idea to at least place 3/8" plate steel (4"x4") at each cornerbehind the front wheels, and ahead of the rear wheels). My question is whether or not it matters if they are welded, or if they can be attached by counter-sunk screws.
There really isn't any "good" place to jack the car without using a 3x3x2 block on the hydraulic jack.
I don't think that I've seen anyone do anything with this yet.
Also: I noticed that Hugo uses a set of Drive-on ramps to lift the from of his car, and I wondered which ones are shallow enough for the nose to clear, yet still give enough lift to get the jack under the car comfortably? I have a scissor jack, but it's more of a PITA to use than it's worth.
I guess I could bite the bullet and get one of the ultra low profile jacks, but I really don't want to spend another $500.00.
