Help required
Has anyone wired the engine worning light yet?
Please post details. I presume the ODBC connection needs to be tapped into however not sure how to do this.
Thx
Help required
Thx
I'm interested in this as well... I've got the light wired in, just not sure where to connect to. Thanks
Bump.
The ford facing module has a red light for failure. Is there a way to tap in to that?
MK3.1 #7076 - Under Construction....
Coyote 5.0/Solid 8.8/Tremec 3650
How to:
Coyote Power Steering
05-09 T3650 in a Roadster
My "Coyote" arrives tomorrow and I'm wondering the same thing... I'll let you know if I figure this out, but if not, I'd certainly appreciate hearing if you find something as well.
Update
I checked with Ford Racing today and there is no support for a dash engine check light (Coyote). Apparently this is too complicated and they did not provide this option for the crate engine.
I will likely hook the red dash light to the 4 way flashers.
