Thread: Coyote Experts - Woring Check Engine Light - Dash wiring
    Senior Member Jester's Avatar
    Question Coyote Experts - Woring Check Engine Light - Dash wiring
    Help required
    Has anyone wired the engine worning light yet?
    Please post details. I presume the ODBC connection needs to be tapped into however not sure how to do this.
    Thx
    Senior Member Slider's Avatar
    Aug 2011
    Fargo, ND
    I'm interested in this as well... I've got the light wired in, just not sure where to connect to. Thanks
    Senior Member ClemsonS197's Avatar
    Marietta, GA
    Bump.
    The ford facing module has a red light for failure. Is there a way to tap in to that?
    MK3.1 #7076 - Under Construction....
    Coyote 5.0/Solid 8.8/Tremec 3650
    How to:
    Coyote Power Steering
    05-09 T3650 in a Roadster
    Aug 2011
    Fargo, ND
    My "Coyote" arrives tomorrow and I'm wondering the same thing... I'll let you know if I figure this out, but if not, I'd certainly appreciate hearing if you find something as well.
    Update
    I checked with Ford Racing today and there is no support for a dash engine check light (Coyote). Apparently this is too complicated and they did not provide this option for the crate engine.
    I will likely hook the red dash light to the 4 way flashers.
