Coyote Q:
Does anyone know of the proper set-up and availability for a power steering pump mount bracket and proper power steering pump (part numbers)? - no AC on my build
Thx
Coyote Q:
Thx
I used the Ford Racing PS bracket and 05-09 Mustang GT power steering pump. It just barely clears the 4" main chassis tube.
Bracket: http://store.jpcracing.com/Coyote-Co...ET_p_1697.html
MK3.1 #7076 - Under Construction....
Coyote 5.0/Solid 8.8/Tremec 3650
How to:
Coyote Power Steering
05-09 T3650 in a Roadster
We have a differant option that is less expensive & closer fitting call Mike!
Forte's Parts Connection: Your Solution Specialist! Motor & Transmission Packages Starting @ $8200.00 Call To Order 508-875-0016
Paht time parts guy!!!!!!!
How to:
Thx Clemson
Do you have a part number for the PS pump and what rack are you running?
Also - what are the specs for the drive belt - part #?
I used 3/8" aluminum plate spaces on the engine mounts to raise the engine (and oil pan) so clearance is increased more than 1/2 inch
I'm running the breeze spacers too, so your clearance wont be any better. The Pump is just a 2005-2009 Mustang GT pump. Available on any Mustang forum or parts store. I need to measure for a belt still. I'm running a 1995 Mustang GT rack. Talking to Ford Racing, I should be fine with that rack, or any other Modular or Fox rack.
How to:
Thx Clemson
I understand the PS pump and Rack need to be set up properly to accomodate for the difference in wight vs a stock mustang i.e. the Mk4 is much less weight and an over-powered PS setup may be twitchy?
I have an AGR rack but need to source the proper pump.
Thoughts?
A lot of people mod the older pumps to reduce pressure. Some people don't mind the quick response if they autocross. I'm going to see what happens before I make changes. Worst case is I add a Heidts valve to adjust pressure.
http://www.heidts.com/steering_kits_components.html
How to:
Hi Guys,
The pump bracket I make fits the later production Coyote engine that are available now from Ford. It features a spring style belt tensioner to keep the belts proper tension. This is not like the pump bracket setup Ford makes.
The Ford Racing bracket pictured by clemson above uses a hinge style mount with a bolt to lever the pump away from the block to tension the belt.
Two different setups and I like the one I make (wonder why?). No climbing under the car to tighten or replace a belt.... Keeps belt properly tensioned throughout the rpm scale.
We are providing the pump with our kit. All together its regularly *******$475.00******** But as we are waiting for more brackets Mike says He will do the first 5 pre orders at ******$450.00******* a kit
