Results 1 to 3 of 3
Thread: 4.6 Footbox Panel?
    Member JeepFlyer's Avatar
    Clovis, NM
    4.6 Footbox Panel?
    If you're putting a coyote in do you need the modfied DS footbox panel (it's labeled 4.6 in the manual) to help with fitment ssues? I realized tonight while I was finishing all of my cockpit panels, that I have the one without the extra bend highlighted in the manual for 4.6 engines. Do I need to make a call to FFR in the morning?
    Wes
    Member rick8928's Avatar
    Baltimore, MD
    yes
    Quote Originally Posted by JeepFlyer View Post
    Yes, you will need the "4.6" driver footbox panel set up.
    Mk IV 7329, '04 Mach 1 donor, 3 link, FFR lowers, heater, Kirkey seats, seat heaters, CobraEarl vents, dual rollbars, 9/10.5 x 17 Halibrand replicas; Kumho Ecsta XS 255/315s, Lexus Indigo Ink Pearl/Artic White stripes, picked up 9/25/10, engine in 7/16/11, first start 3/9/12, go kart 3/18/12, first drive in primer 4/1/12, tags/title 4/16/12, paint 6/8/12, complete 7/24/12
    Mustang Convert bansheekev's Avatar
    Morgan Hill, CA
    Yep, it is actually two pieces:
    1) The vertical panel between the engine and the gas pedal
    2) The top cover facing the underside of the hood (the additional bend is built into this piece as well)
    MKIV, IRS/TruTrack/3.55s, Coyote, TKO600, Wilwoods
    Delivered: 1/6/2012
    First Start: 1/19/2014
    First Go-Kart: 2/1/2014
    Graduation: 1/4/2015
    Graduation Thread
