Results 1 to 22 of 22
Thread: Fuel Line Plumbing
    Member JeepFlyer's Avatar
    Clovis, NM
    Fuel Line Plumbing
    I'm about to start my fuel and brake lines without my engine being here. I just wondered if someone could post some pics of their coyote in the frame so I could see an approximate location to run my solid fuel lines to, before they switch over to flexible hose. Thanks.
    Wes
    Mathis, TX
    Hey, Cleco! How's your hammer hangin'? Hope your build is going well and you're well stocked on Clecos and Rivet Nuts. The group in our school was outstanding and it was a great experience. Anybody who is going to build a car needs to go.
    Steve (short fat guy with white hair)
    Senior Member ClemsonS197's Avatar
    Marietta, GA
    Here's what I did. Used tubing from Summit and added AN fittings.
    MK3.1 #7076 - Under Construction....
    Coyote 5.0/Solid 8.8/Tremec 3650
    How to:
    Coyote Power Steering
    05-09 T3650 in a Roadster
    Clovis, NM
    Steve,
    It's going well. Finishing up sheet metal and moving on to brake and fuel lines. I'm kinda skipping around because I am waiting on different parts here and there.
    Clemson, is the fuel line hookup on the DS of the engine? It looks like your flexible hose is heading that way. I definitely like the location for the regulator. I'll have some extra room since I don't have a heater to mount up there.
    Wes
    Marietta, GA
    DS front of motor.
    How to:
    Administrator David's Avatar
    Eldo CA
    Clemson,
    Would it be possible to run the fuel line through the tunnel as another option?
    Also, what fuel regulator did you go with?
    Mk4 Build Thread: http://thefactoryfiveforum.com/showthread.php?141-David-s-Mk4-Build-Thread
    GTM Project Build site: http://www.gtmbuild.com
    Few Cool GTM Parts: http://www.gtmbuild.com/parts.htm
    Senior Member tcoon's Avatar
    Angwin, CA
    Engine fuel inlet on top of DS fuel rail. It's probably not a good idea to run the fuel lines through the tunnel. Last summer at Thunderhill raceway there was a situation where a car builder had done that very thing...the driver shredded a clutch, which then became shrapnel and pierced the non SFI bell housing, as well as the nearby fuel lines! The resulting fire was not pretty. Suggest keeping the fuel lines outside the frame rail for safety.
    Coyote powered Daytona Coupe Competition Racecar #21
    Challenge series #21
    FFR 33 Hot Rod
    2009 3rd place NorCal series
    2010 3rd place West Coast series
    2011 2nd place NorCal, 2nd place West Coast Series, 3rd place WERC class E1
    Mustang Convert bansheekev's Avatar
    Morgan Hill, CA
    My routing under the car is pretty much the same as Clemson's - outside the framerail under the passanger side. I brought them up along the passenger footbox althought they are not expanded footboxes. I choose the Aeromotive A1000-6 regulator.
    Kevin
    Quote Originally Posted by David View Post
    Clemson,
    MKIV, IRS/TruTrack/3.55s, Coyote, TKO600, Wilwoods
    Delivered: 1/6/2012
    First Start: 1/19/2014
    First Go-Kart: 2/1/2014
    Graduation: 1/4/2015
    Graduation Thread
    Marietta, GA
    I thought about running inside the frame rails, but my bellhousing was rather tight, plus the trans bracket is in the way.
    I used the same regulator as bansheekev.
    http://www.summitracing.com/parts/aei-13109
    How to:
    Eldo CA
    Thanks for the feedback guys.
    Another question... Are you guys running the 5/16 fuel line provided by FFR, or going to 3/8" line?
    Marietta, GA
    They say 5/16 works but I used 3/8 because it's a lot easier to get AN fittings for the rest of the connections with 3/8. I bought summit tubing and flared everything 37° for AN.
    How to:
    hmm, I am in the middle of the feul portion of my build. I am using the 3/8 alum tubing in parts of it. I am welding AN adapters on the ends of the tubing. I saw the conectors availiable, but I thought they were only rated to about 35psi. I am running EFI, which of course needs 60psi. What do you guys think? I'm sure guys are doing it like the pics above, and haveing no problems?
    Just wondering,
    Gene
    Marietta, GA
    That can't be right. AN fittings are only rated to 35 psi? I'm running my regulator at 55 psi no problems.
    How to:
    Quote Originally Posted by ClemsonS197 View Post
    AN fittings are routinely used for power steering/power brakes, where the PSI can be well over 1000.
    Eldo CA
    +1... should be good for 10X + that.
    I don't know, I'm only going on what I read. This discription does not say a specific preasure but it does say it's good for low preasure. http://www.summitracing.com/parts/ea...6erl/overview/
    I realize AN fittings are good for high preasure, but I was talking about the AN to tube fittings, the tubeing portion of it, not the AN portion of it. Well I can't find the discription that gave a specific preasure rating, but I did see it. I even saw certian aluminum tubing that was only rated for lower preasures. I am useing Earls tubing, it is givin a 100 psi rating.
    http://www.jegs.com/i/JEGS-Performan...oductId=753765
    http://www.jegs.com/p/Earls/Earls-An...74866/10002/-1
    Just checking,
    Gene
    Eldo CA
    What are you guys using to interface with the Coyote fuel rails? I suspect there is some sort of AN6 adapter available?
    Marietta, GA
    Blue: http://www.summitracing.com/parts/RUS-640850/
    Black: http://www.summitracing.com/parts/RUS-640853/
    How to:
    Eldo CA
    Thanks!
    Clovis, NM
    Quote Originally Posted by bansheekev View Post
    How much room is there around that diagonal support from the frame rail to the firewall? I ask because I have a fuel filter I want to mount there. It's probably under 2 inches in diameter.
    Wes
    Mar 2013
    ny
    Thinking of going nylon fuel line like oem, I've read about braided weeping fumes. The fuel regulator takes a orb -6 Fitting, 799-644020.jpg Push-On EFI, Straight, Male -6 AN, Male Quick-Connect 3/8 in., Zinc Plated Russell 644020 think this fitting would work then I could just go nylon fuel line from regulator to ford fuel rail. Just need to know if I'm correct on the regulator fitting side.
    http://www.russellperformance.com/mc...fuel-efi.shtml
    Mar 2013
    ny
    I ended up using the nylon lines very clean and easy to work with.
