Thread: Wheel Clearance
    Superannuated Member
    Virginia
    Wheel Clearance
    Got the axle centered and threw the wheels on to check the accuracy. Turns out they go on with only millimeters clearance between the wheel rim and the shock absorber bracket. These are the FFR 17 X 10.5 Halibrand replica wheels on a fox length axle.
    http://i1179.photobucket.com/albums/...d/DSCN0431.jpg
    http://i1179.photobucket.com/albums/...DSCN0434-1.jpg
    So I'm uncomfortable with this kind of clearance and thinking I need different wheels.
    Senior Member rj35pj's Avatar
    Marion, IN
    I had the same concerns with the same wheel combination. Others on the forum said no problem and they were correct. There is no movement there and I have had no problems.
    Henley MO
    I used A 98 rear axel it's slightly wider and already 5 lug and disk brake. fits fine.
    Colorado Springs
    I'v seen pictures like this before. And people with similar set ups say there's no problem.
    But, like you, I would be uncomfortable with clearances that tight. I would trim that corner, and then weld in a small plate to close it off.
    .boB "Iron Man"
    www.RacingTheExocet.com
    Senior Member turbonut48's Avatar
    Milwaukee, Wi.
    A .060 spacer behind the wheel would give you plenty of clearance.
    Its not enough to upset your tire stick out from the body.
    The Nut
    Trick Tool Maker, Super Moderator Hankl's Avatar
    Northern CA
    With the area that is closest to the wheel, a slight chamfering of the area with a 4 1/2" grinder would easy take off .060-.080,
    and give you the peace of mind you need and not affect the integrity of the bracket.
    Hank
    “If you didn’t have enough time to do it right the first time. How come you always have time to go back and do it again?” FFR1000186CP
    Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car.
    Horsepower is how fast you hit the wall and torque is how far you take the wall with you.
    Virginia
    Thanks, folks, for your instruction. I'll try removing a little material on the bracket first and see how that works out.
