Results 1 to 3 of 3
Thread: #377 build
    Aug 2011
    Midland, Texas
    #377 build
    Just started back on my build. Installed QA1s and the grille assembly. Had to cut off the top hole on the mounts so it would fit. Was not easy to get the radiator, condensor and grille all lined up. Also had to twist the mounts to get it all mounted. Sure hope that doesn't cause any problems later.
    Aug 2011
    Midland, Texas
    Finally after 4 years, I've go carted!!! Cranked up on 2nd turn of the key. Had minor antifreeze leak and fuel level and water temp gages didn't work. Sounds good with Flowmaster super HP2 mufflers. Hope to get a video posted next week.
    Jun 2012
    CrossRoads, Pa.
    congratulations Sheephearder, I'll bet it feels good to get that milestone under your belt. looking forward to seeing the video.
    Nevin
    Nevin, AKA H. R. Lucky
