Just started back on my build. Installed QA1s and the grille assembly. Had to cut off the top hole on the mounts so it would fit. Was not easy to get the radiator, condensor and grille all lined up. Also had to twist the mounts to get it all mounted. Sure hope that doesn't cause any problems later.
