Just a couple of final pictures from the past week or so of work. These show the old-style FFR soft top bow in place. Before installing it, I reinstalled the under-body braces that I made and wrote about in an earlier post above. I had those powdercoated as they'll be slightly visible under the edge of the rear cowl, so they now match the frame. In these pics, those supports are just held in by clecos and then the ferrules are just slipped through the body... no bonding was applied. However, the installation is super rigid and I'm sure there will be no problems with the top flexing and causing cracks in the fiberglass or paint around those ferrules.
