Well this week was supposed to be a time to celebrate the first start of GTM #357. Unfortunately, my "slightly used" LS3 is showing NO signs of life.
When I turn on the ignition I hear the fuel pump running and fuel going to the fuel rails. When I crank the starter it turns over fine, but no signs of starting beyond that. In fact, I don't seem to be getting any injector pulse or ignition spark. I checked all connections to all sensors, all power connections, and grounds (~3-4 times!). Everything is hooked up fine. I even went so far as to change out the Cam sensor and Crank sensor thinking the ECU wasn't seeing the engine turning over causing starting difficulties. Drilling down further on the diagnostics I'm getting no trouble codes from the ECU but it also doesn't seem to be getting info from all sensors.
I'm using the ISIS system, and in talking to the supplier who sold me the engine, custom harness, and ECU there are some reports out there of people having similar trouble with ISIS in the mix. He also told me there is some sort of security mode that is tripped if the power connections to the ECU aren't right.
I realize this could be a million things, but does anyone have ideas about next steps to diagnose this problem? Is there a known issue with the ISIS powering the ECU adequately for starting conditions?
I'm ready to bring this build to life but I'm totally stumped. Thanks.
