I am working on an almost done coupe that I am installing a/c in. Can some of you post some pictures of how to mount the condenser, and several pictures on the lines. Thanks, Larry
All the lines exit towards rear of motor as in bottom pic.
I have a coupe in Clovis with a/c if you want to look at it.
