0
0
Radiator Aluminum Ducting
Could someone please explain or show pictures of how the center and side aluminum ducting fits in relation to the radiator, height-wise....When I do a dry fit, the side ducting is approximately level with the top of the radiator and the bottom of the radiator center duct with the weatherstripping is hanging approximatley two inches below the bottom of the radiator. I am concerned about riveting the side panels and then finding out the fit is off when I lower the body nose, either low or high. Also, it appears I will have to trim the driver side ducting in order to fit the radiator hose properly. Am I off on my positioning....
Does this pic help?
First Time Builder
Mike, for a good result you'll want to wait until you have the hood sitting where you want it to fit these aluminum pieces. With the car up on stands with the hood closed and the front tires removed, I used some spring clamps to hold the side pieces in place long enough to mark them.
Also, if you don't have your radiator plumbed yet, wait to mount the driver's side piece of ducting until you do. I had to trim mine a bit to clear the hose coming out of the radiator...
Your side panels are in line with the top of the radiator height-wise, so thanks for the heading check. I will definitely have to trim the driver's side panel to route the hose.
- You may not post replies
- You may not edit your posts
Forum Rules
