Results 1 to 4 of 4
Thread: !!!!Headlights!!!!!!
    Forte's Parts Connection
    snakeboost's Avatar
    Framingham Ma on a computer
    First is our top of the line:
    DIE-CAST OEM REPLACEMENT HEADLIGHTAttachment 13412
    > Glass Lens
    > Multi-Surface Reflector
    > Die-Cast Aluminum Housing
    These sealed beam housings are designed to not only give your vehicle an updated look but 30% more light output with their Multi-Surface Reflector Technology. No modifications are necessary, just plug-and-play. Add our superwhite series halogen insert bulbs and get over 60% additional light output over your factory housings.
    These come empty [no bulbs] for $140.00 regular. I have 5 sets on the shelf & 5 coming in Mike says we can sell for $115.00 a pair with bulbs!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!
    Forte's Parts Connection: Your Solution Specialist! Motor & Transmission Packages Starting @ $8200.00 Call To Order 508-875-0016
    Paht time parts guy!!!!!!!
    snakeboost's Avatar
    Tri bar styles!!!!!!!!!!!!!!!!!!
    We have 2!
    The first is blue dot with turn signal tri bar setups [yes they are made in China] These also have bulbs & are $75.00 a pair! These are plastic housing & lensAttachment 13414
    The second is clear dot without turn signal [also made in China] These come with bulbs & are also $75.00 a pair!!! These are plastic housing & lens
    snakeboost's Avatar
    We have more of the first style back in stock!!!!!!
    Denton, Texas
    The DIE-CAST OEM REPLACEMENT HEADLIGHT "plug and play" have the three prong connection and the same mounting as the Factory Five Roadsterscomplete kit?
    FFR 7079 Mk3.1 Complete Kit, Ford Racing 302, ~340HP, Powerjection III EFI w/spark control, T5, 3.73, PS, Kirkey seats, Heater/Defroster, Seat Heaters, Earl's Vents, Mike's heat shields, Herb's door panels, Dark Water Splash Guards, ********** seat belt cross-member, custom car cover by carcoverworld, Whitby's Grabber Blue paint, and so much more to go
