I hate to ask this question as it has probably been asked many times over. The build manual for a base kit says to mount the UCA to the horizontal mounts. A lot of pictures I look at have them mounted vertically. I have the spindles from a 99 Mustang, SN 95, so which is correct? The research I have done says that the Complete Kit with the FFR spindles uses the vertical mounts, and the donors use the horizontal mounts. Is the manual just assuming (I hate that word) everyone is using the FFR spindles? This is on a Mark IV also.
Thanks in advance, Mike.
