Thread: Factory Five MKIV Roadster Complete Kit plus more
Hybrid View
    Dec 2012
    Richmond, VA
    SOLD
    Factory Five Mark IV Roadster for sale - Richmond, VA area
    SOLD
    I have a new addition to the family and won't be able to complete the assembly of my kit car. I hate to see it go but family has to come first. Just about everything you need including oils are in this package. I also have an engine stand, engine hoist and some Matco tools for sale separately to help put everything together. A combo deal could be worked out to include the kit car package, tools and engine stand and hoist. (See below)
    Here is what is included in this Cobra package: $29,000 negotiable
    Factory Five Mark IV roadster Complete kit (retails for $19,990 by itself)
    - too much to list individually, go to https://www.factoryfive.com/kits/mk4.../what-you-get/ to see everything that comes in the Complete kit
    - Ford Racing 5.0 L Coyote Engine w/ flywheel (rated at 412hp / 390 ft-lb torque) Emissions legal
    - Ford Racing Engine install kit (ECU, wiring harness)
    - Ford Racing Tremec 6-Speed Transmission
    - Hudlow Axle Custom Rear end Assembly (posi, Ford 8.8, 3.73 gears, 31 spline axles)
    - Brembo Front Brake Kit (rotors, brackets, lines)
    - Ford Racing rear brake kit
    - Auto Xtra Ceramic disk brakes
    - A1 Cardone Friction choice calipers (left & right) (18-B4824) (18-B4825) $61.95 each
    - Royal Purple engine oil, transmission oil, gear oil
    - Weld Wheels Forged Five Spoke Front 17 x 11, Rear 17 x 12
    - Mickey Thompson Street Comp Tires - Front 245/45R17
    - Mickey Thompson ET Street Radial II - Rear 315/35R17
    8_Matco_JSC500_ServiceCart.jpg1_BodyFrame_Front.jpg2_BodyFrame_Rear.jpg3_PartsBoxes.jpg4_FordRacing_Engine.jpg5_Tremec_Transmission.jpg6_HudlowAxle_RearEndAssembly.jpg7_WeldForgedWheels_MickeyThompsonTires.jpg
    The following items are being sold separately from the kit car package. If you wanted to buy everything together then I could do a combo deal of $33,000
    Engine stand and Engine hoist from Summit Racing - sell for $250 for both
    Tools for Sale: $4150 for all shown below
    Matco Tool Box - Jamestown Service Cart JSC500
    Matco Tools
    - 12 pc Opti-Torque Pro Long Combination wrench set (SMCL122T)
    - 10 pc Opti-Torque Pro Extra Long Combination Metric wrench set (SMCXLM10T)
    - 3 pc Multi-Position Prybar set (IDPOSET3)
    - 8 pc Screwdrivers set (SSO8C)
    - 18 volt ½" Drill Driver Kit (MCL18DDKIT)
    - ½" Impact Wrench (MT1769A)
    - 3 pc Extra Long Needle Nose Pliers set (PNO3SB)
    - 3 pc High Leverage cutting pliers set (SPDC3)
    - 3 pc Alligator Pliers set (PA3S)
    - 3 pc Wire striper / crimper (MST700E)
    - Torque Wrench TRC150 (CG3150FTC-MTB)
    - Klik Fast rivet tool HP-2 riveter (61660) not full kit (kit price $93.85)
    - 3 pc ratchet set 1/4th, 3/8th, 1/2th (SRTD3T)
    - 1/4th SAE socket set 9/16th -- 3/15th (SA106TB) qty 2
    - 1/4th Metric socket set 6 -14 mm (SAM92TB)
    - 3/8th SAE socket set 1" -- 1/4th " (SB136TA)
    - 3/8th Metric socket set 19mm -- 8mm (SBM122TA)
    - 3/8th Metric socket set 22mm -- 6mm (SBM176TA)
    - 1" SAE socket set 1" -- 7/16th" (SC106TA)
    - 1" Metric socket set 24mm -- 10mm (SCM156TA)
    Roanoke Rapids NC
    I am interested in your car. How can I contact you?
    Dec 2012
    Richmond, VA
    Quote Originally Posted by rrtang View Post
    You can always send me a private message. Click my user name and select Private Message from the menu.
    Dec 2012
    Richmond, VA
    Car Package and Tools now Sold.
    Thank you.
    Senior Member Raceral's Avatar
    Stoneville NC
    Somebody got a heck of a deal.
    Al Adkins
    Certified "Kool Aid" drinker
    Owensboro, KY
    Quote Originally Posted by Raceral View Post
    Yea! Helluva deal!
