Coyote torque specs
I'm looking for torque specs for my coyote build.
1.Fly wheel do I need blue locktite?
2. Bell housing to engine?
3. Pressure plate to Fly wheel?
4. Tremec to rear bell housing?
Thanks much
DANW
2. Bell housing to engine? 35 ft lb
3. Pressure plate to Fly wheel? 33 ft lb plus 60 degrees
4. Tremec to rear bell housing? 45-65 ft lb
Thanks much
You should double check with FRPP re blue locktite however the torque specs they provided me are listed above
Thanks Jester, did they say what to torque the fly wheel down to? Also I am not sure what you mean by torque the pressure plate down to 33 ft lbs plus 60 degrees, I have read that before and not sure what the 60 degrees means.
Thanks.
DANW
Thanks.
The plus 60 degrees means that you torque to the required setting then add an additional +60 degree turn to the bolt
Torque to for the flywheel to the crank is 80 ft lbs
Thanks and Happy New Year!!
Thx - Glad to help - good luck
Happy new year!
