Artistwantab,
Just my 2 cents on the lift. I have a BendPak XPR-10A. Simply outstanding. I know some folks like the 4-post lifts - I'm a 2-post guy. I feel it affords much better access to everything under the car, easy suspension/brake work, just can't say enough. Yesterday I had to remove my GTM doors for the first time in about a year. I was having trouble pulling the hinge pins out from the top, so I lifted the car and was able to use a rod from underneath and tap them out. On a four post lift the tracks that the wheels ride on would have been directly in the way ... with the 2-post, no problemo!
And when I reassemble, I may put the hinge pins in from the bottom with the nut on top - may be easier to remove later.
Best of luck!
-Michael
