17
Made the aluminum panels to support the ISIS front power cell and the master cell. They will go were the master cylinders were before i put the power brake package on.
Here is the cardboard mock up
Had to cut away the 2 posts that held the brake parts
Made a support that will be riveted to back side of firewall chassis and used 2 bolts that hold up the pedal box to support panel.
Still have to mount the modules. Now the access panel in the cowl of the body will be used to maintain the fuses in the powercell rather than brake maintenance.
Nick Sebastian - 33 Hot Rod #495
Factory Five Forums - hdnik
FFCars - lowntubd
Build Site/Blog -
www.nicks33hotrod.com
