I have to agree with Arrowhead. You really need to take advantage of all the radiator surface area you've got! I used one of Mike's shrouds too and mounting the fan inside was very tempting. It looks very clean and with the condenser mounted on the front of the radiator, and the fan mounted OUTSIDE the shroud on the back, the whole package becomes quite wide. In fact, when installed on my car, the top shock mounts just barely touch the plastic fan cover with the suspension at full extension. It shouldn't be a problem, but if that package were a half-inch wider, it wouldn't work!
