For those installing the 2005+Mustang trans, how did you hookup the hydraulic TO bearing? Its got a bit of an odd looking connector on it, but not sure mine is complete. Any tips would be appreciated.
Mk4 Build Thread: http://thefactoryfiveforum.com/showthread.php?141-David-s-Mk4-Build-Thread
GTM Project Build site: http://www.gtmbuild.com
Few Cool GTM Parts: http://www.gtmbuild.com/parts.htm
David,
Check out this post:
http://thefactoryfiveforum.com/showt...-with-a-Coyote
The line I used is this:
http://www.summitracing.com/parts/MCL-139251/
This has the fitting you need to go into the trans. It's AN-4 on both ends so you should be able to ditch the clutch side and use an AN-4 fitting or adapter on the Wilwood pedals. There is a small "U" shaped piece of metal that locks this fitting to the piece on the trans. My local Ford would not sell me that small piece, and I had to get a salvage yard to get one for me.
MK3.1 #7076 - Under Construction....
Coyote 5.0/Solid 8.8/Tremec 3650
How to:
Coyote Power Steering
05-09 T3650 in a Roadster
