Hi,
I'm having a problem with the FFR / Moser rear end I purchased with my 33 Hot Rod kit in November 2010.
*The measurement between the wheel mounting surfaces is 59 1/4" (correct)
*The measurement between axle housing end flanges is 53 7/8" (incorrect, should be 54 1/4")
*The measurement should be 2 1/2" from the axle shaft wheel mounting surface to the axle tube brake mounting surface
*The measurements on mine are as follows: right side 2 3/4", left side 2 5/8". This means that the right side axle tube is 1/4" too short and the left side tube is 1/8" too short.
*With these dimensions being incorrect, my rear brake calipers are not even close to fitting.
Thanks for all of your help.
Jeff Davis
