Ball Joint Torquing Question
Did my front end today. I new I'd have an issue torquing the lower crown nut to 125 due to clearance and as you guess I don't have a 15/16 crows foot... But while doing the upper I noticed I could not get to 125. I mean it was tight as hell but I buried the upper cron nut almost past the cotter pin hole and my torque wrench hadn't click yet. I left them there and did the lowers with the spacer and a long wrench... Buried those almost past the hole as well.
How do you get 125 # on these and not got too far?
Nick Sebastian - 33 Hot Rod #495
Factory Five Forums - hdnik
FFCars - lowntubd
Build Site/Blog -
www.nicks33hotrod.com
In the type 65 coupe manual the torque spec is 80-120 lbft.
Bill Lomenick
Tech Support Manager, FFR
Hi guys for the ball joints the torque spec is 85 lb ft Tony@ffr
I am looking at Revision M of the manual. Page 43 says 125 ft-lbs on the lower ball joints. The chart on Page 45 says 80-120 ft lb on lower, it also says 70-90 for the upper ball joint. This is why some of us are confused. You are rcommending the same torque for both ball joints?
www.33coyote.com
Built with the help of my dad and sons
coyote/TKO 600, Wilwood Brakes,Boyds tank, QA1 shocks
Speedhut Gages, rag top, bike fenders, power steering
"Never let physics or common sense get in the way of a good idea"
