Thanks Thanks:  2
Likes Likes:  15
Results 1 to 40 of 115
Thread: Lucky's 33 Hot Rod build #524
Threaded View
  1. #14
    Senior Member H R Lucky's Avatar
    Jun 2012
    CrossRoads, Pa.
    build update - I had to replace the clutch master cyl. couldn't get enough travel out of the .75 in. cyl., I replaced with a 1.125 in. it works fine now. also, I decided to replace the original mufflers after hearing all the stories about fiberglass chicken feathers blowing out the pipes; I went with the Flow Master HP2's because of the cool temp technology as they will be right under my seat. (thanks to Glenn Somers for the idea)
    I also trimmed my FBW original Ford gas pedal, I did not modify it like the manual says to, instead I just mounted it against the firewall in it's original shape & it works fine except it was a little long so I trimmed the bottom for more room against the floor.
    Pictures:
    Nevin, AKA H. R. Lucky
    33 Hot Rod sn 524 build started 3/18/2013, First Start-5/09/2015, Go Cart-6/01/2015
    5.0 Coyote engine, 9in. Ford rear, 4 Link, Wilwood 12in. front brakes
    AC, power steering, FFR 17/18in. Hot Rod wheels
