Trying to get most of the wiring out of the way, I had headlights,(hi-lo beam) tailights, brake lights, park lights, running lights, but no turn signals or hazzard lights; also the horn didn't work either. After trouble shooting & scratching my head for about a week, I was thinking there was something wrong in the I-didit column, I called FFR and Dan suggested that I put in the original flashers instesd of the LED flashers, while I was removing them I read some fine print on the flasher; it said 'input line X should be connected to a fused circuit' right then I had a brain awakening as I knew from trouble shooting that the other wire to the flasher was coming from the fuse box, so I switched the wires in the connector & lo & behold the turn signals started working! It was the same problem with the Hazzards, switched the wires and the 4 ways worked now also! The last problem was the horn which I found out from one of the forum members (erlihemi) that it was missing the little black plastic barrel connector with the spring loaded ground wire for the horn. I was able to get one from a vendor at a car show this weekend & that fixed the horn. Getting these problems out of the way is a load off my plate, So, next will be to install & connect the gauges.
