Thread: Roadster Chassis Rotisserie
    I'm thinking of using a rotisserie to build up the chassis with everything but the engine, trans and tires. Can I use the quick jack mounts as pickup points or are they insufficient structurally to hold the load?
    Bill D
    Fresno, CA
    Bill, A friend up here in the Central Valley did just that with his MKIII and it worked great. He used the same rotisserie for restore his 66 Mustang.
    Doug
    Super Moderator oldguy668's Avatar
    I found this to work just great. Note the blocks under the tires. The unit is rock solid without the engine crane in place. I just left the crane as extra insurance, but it really wasn't necessary. The whole shebang reaches a tipover point just before it rests on the tires, so it ain't goin' nowhere.
    "Loyalty to the country always. Loyalty to the government when it deserves it".
    Mark Twain
    Tech Manager, FFR
    Hi Bill - I'm a little late with this post but thought I'd mention it anyway: We clamp to the X-member up front and use the rear quickjack mounts in the back. That can still be a fairy high amount of weight to leave sitting for a long time on there, but it would be stronger if you installed the trunk side walls first.
    Jason @ FFR
    Thanks Jason
