Slider,
Did you run the Orange and Black wires from the Controls Pack directly to the fan + and -? Or, did you splice into the FF harness? If you ran the Orange and Black directly it should be fine. If you didn't, and you spliced into the FF harness, let me know... I went through some trial and error to get it to work using the Controls Pack Orange wire as a 12V trigger to the FF harness relay to allow me to use the FF harness wiring for the fan.
Was your 210 degree measurement from the dash gauge? If so, where is your gauge sensor located?
Kevin
