Results 1 to 9 of 9
Thread: Top Feed Fuel Injector O-rings
    Mechie3's Avatar
    There is someone on ebay that sells top feed injector o-ring kits for ~ $24. Includes new injector filters too. Cheaper than going to Subaru. I've used these several times successfully. In a pinch (literally, when you pinch an o-ring and dump fuel all over your motor :meh: ) this doesn't work unless you want to wait for shipping.
    Turns out the 97 Toyota Camry 4 cylinder (and some 281 other Toyota models, I just used the Camry as my example) gives you the same thing. It includes a small o-ring for the top, the upper rubber isolator, and the lower rubber seal. There is also a large o-ring that we don't need.
    O'Reilly sells it under p/n BWD 274531.
    CHECK THE BOX! One O'reilly only had boxes with 2 large o-rings. The other o'reilly had the correct assortment. Cost is $4. If you don't need/want the fuel injector filters it's cheaper than the ebay kit and available now.
    http://www.oreillyauto.com/site/c/de...2524&ppt=C0024
    Zero Decibel Motorsports
    Does my '02 WRX have top feed injectors? I don't know what that means. If not, what kind of O rings, etc. can I use?
    Mechie3's Avatar
    Yes.
    Top feed = fuel rail fits on top of injector. Fuel flows top to bottom. Believe all wrx are top feed as are 07+ sti.
    Side feed = injector fits onto rail. Fuel flows in side and out bottom. Some STi's were side feed.
    Jan 2012
    Damn mechie it's only $4 for the bwd kit from Oreilly and your paying retail? That's cheaper than my employee account with them...
    Mechie3's Avatar
    Maybe you're getting scammed. :lol:
    Hey, what's the retail on one of those?
    More than you can afford pal...Ferrari.
    Freeport, ME
    I just checked w my local store... $3.99
    Dan
    Jan 2012
    I'm in Cali everything is more expensive. Nice fast and furious comment.
    Jan 2012
    Special order for me. So I have to paying the 7.99 freight charge plus the actual item. Item is about the same. Employee discount does not apply for special orders.
    Smoke 'em
    One IPO here we go.
