what size seat did you get? large ? what size does that cover exactly? I can't find any info vs inseam. do you think the med would have the same problem?
Nolan
Yeah it's the large. Not sure how the widths differ between sizes. I'm 36-38 waist, 36 in the summerso a 38 now and it's snug, but not uncomfortable.
818 SRX - #91
Arrived 01/02/2014
First Start 10/31/2016
First Drive 05/22/2017
Registered 10/25/2019 BRAP818
You will probably never drive the car in your 38 waist anyway, cuz it's during winter!![]()
Tracked May 27/July 26, 2017
Build Completed Winter 2021
818 SRX - #91
Arrived 01/02/2014
Final mock up before drilling holes. I'm really unsure of what to do with the shifter. The manual shows it mounted between the seats, in which case it would have to be under mounted. When I checked out longisland and mechie's threads about how they did it, they mounted it ahead of the seats. Since my seat is so far back, I almost want to mount it ahead of the seats and on top. If they can mount it up there then there must be enough cable length. Still need to modify it though, as I'll be punching myself in the leg for 1st every time.
Got the seat support rails welded, and drivers seat bolted in. Measured clearance for the gas tank and started cutting.
For anyone wondering, the FFR tank has a baffle/bowl in it. I was planning to weld something in while it was open, but I was pleasantly surprised.
I also removed the filler port on the back.
Here's the idea.
Need a little more clearance, then its time to modify the fire wall and fabricate the engine side firewall.
818 SRX - #91
Arrived 01/02/2014
Started mounting my harness. Didn't feel like drilling 9/16" holes, so I'll punch out some brackets tomorrow at work to make my lap and sub belt mounts. Had to remove the seat belt bracket behind the seat in order to wrap the harness. Put the buckle on the bottom to keep the harness at an angle that doesn't have it ride on the seat grommet.
818 SRX - #91
Arrived 01/02/2014
You cut the console rails? You're a monster.
My plan is to mount my shifter so the knob is close to my right hand when it's at 3 o'clock on the steering wheel without interfering with my steering input. Mounted close. When I need to shift at an auto-x or a rare track day I have to move my hand the least distance to shift and get it right back on the wheel.
Kind of like the WRC cars or NASCAR cars.
I agree Rasmus, no need to have it crazy low.
Can anyone help me with getting the FFR supplied shifter apart? There's a washer that needs to come off, but I have no idea how. I had to walk away before I broke it. I'll take a pic later, so those without a kit can advise too.
818 SRX - #91
Arrived 01/02/2014
Pop the washer with slots off. Either pry it or put it in a press. Pop off the two metal retaining tabs then give the bottom nub of the steel lever a good wack to pop off the plastic cup that was held in place by the clips.
Zero Decibel Motorsports
Check out my new website!
Thanks Mechie, I was timid about the washer. Got rough with it after your post and success! Here's a thought; I'm going to press the ball off tomorrow to rotate the shaft to the passenger side. The ball is centred on the splined section, if I were to put it back higher on the shaft wouldn't it shorten the throw?
818 SRX - #91
Arrived 01/02/2014
It would shorten it. Just make sure you still have enough clearance below (not sure why you wouldn't).
818 SRX - #91
Arrived 01/02/2014
Wow, been awhile since I updated this. Working on brake/clutch hard lines this weekend, and like everyone else, the kit didn't come with enough of the right size lines. Fortunately they're only $5 a line at the local auto parts store. I want to run the lines slightly different, and I'm looking for feedback. In the pic below, I want to run both lines up and over where the green tape is on the outside of the frame. The cross over will be along the engine mounts. Will this interfere with anything further along in the build?
818 SRX - #91
Arrived 01/02/2014
"Scotty, give me all the TRACTION she's got!" Pictures of what I drive till 818R is finished
Track Car Journal on IWSTI (with build info)
Haha, nothing of the sort! I'll update the thread tonight or tomorrow with pics of the shifter and gas tank/firewall mods. I just got back from the store with more lines so I'm going to go ahead and mount them as discussed above. Really don't like the idea of having brake line so close to a header/manifold.
818 SRX - #91
Arrived 01/02/2014
Yea! That (routing near the exhaust) was a biggie for me. Where will you T it? I was thinking of somewhere in front of the gas tank area.
I'll post pics if it works out,
Plan is to tee by the drivers rear upper shock mount, also going to end the clutch line there and use a longer braided hose to the tranny.
818 SRX - #91
Arrived 01/02/2014
Finished routing all my hard lines. Everything is just cleco'd in place, but I don't see reason to not go ahead and rivet everything. I'll add a few more p-clamps.
My Nissan 300zx aluminum calipers showed up, along with the brackets from KNS. Looks like I'm going to need larger rotors! Those are the 2.5i rotors, about an inch smaller than the Legacy GT 315x30mm rotors I need to order. I'll weight everything later when I have the front rotors, but the massive (in comparison) aluminum 4 pots seem to weigh about the same as the oem cast 2 piston sliders.
The back will be more difficult. The Nissan 2 pot rears are slightly different than the wrx ones. They'll mount to wrx backing plates but the pad will sit a few mm off the edge of the rotor. It seems a few people have run it like this and I can't find any ill reports, however I'm going to try to avoid it. I don't have wrx backing plates, so I'll attempt to make a adapter like the front. If that doesn't work, I'll get the wrx backing plates and slot/weld the mounting holes to move the caliper in over the rotor.
818 SRX - #91
Arrived 01/02/2014
Couple of questions on the hard lines:
1. I did not see the clutch hard line, was this also run
2. Also any reason not to run the bias to cockpit area so you can adjust from there ?
3. I did not see where you split the rear lines for each side, also any reason not to run them down the center console area and then tee near gas tank? Seems where you have it on the side is where the aluminum panels go (at least the R has these side aluminum panels).
4. Have any pics of where you mounted the tabs for hardline to flex line ?
Tony Nadalin
2018 SOVREN Big Bore Champion
2012 ICSCC ITE Class Champion
818R Build in progress
1. In the second pic, the line on the right is for the clutch. Also the top line in the third pic.
2. I don't expect to be adjusting the bias often, dial it in once, tweak it on occasion. Wilwood makes a nice cable adapted knob for mounting in the cab, I believe CPlaven has one in his build thread. I need to get some seat time, only done auto x, and that was 9 years ago. I'd rather not have knobs to fiddle with, at least for now.
3. In the fourth pic, just above the coilover is the rear tee. All the aluminum panels on the S are inside the cockpit. You could go down the tunnel and split at the tank, probably a little more work though. I no longer have a centre tunnel, for now anyway, and my gas tank/firewall/seat area is already way too tight.
4. I'll take some pics of the flex line mounts tonight.
818 SRX - #91
Arrived 01/02/2014
818 SRX - #91
Arrived 01/02/2014
My thread seems overly pic heavy. IMO its the best way to do a build thread. I think its the lack of conversation that usually spreads out threads, but most of what I'm posting is either already sorted from past threads, or one off stuff no one will be copying.
Removed my rear dust shields to start fitting the wrx rotor and Nissan caliper.
The rotor is quite bigger/wider and is vented vs the 2.5i rotor. Its actually about the same size as the OEM front.
818 SRX - #91
Arrived 01/02/2014
Few things I've done in the past month that I forgot to update...
Fabricated some harness and seat mounts
Made this shifter mount using 14ga steel and 1.5" dimple die. Also pulled the shifter apart and rotated the shaft so I'm not punching my leg for 1st.
TIG welded up the gas tank. Its notched to allow the seats to move back another inch, and I relocated the fill tube so its no longer near the exhaust. I checked it with dye penetrate, waiting to bolt it in and test fit everything before sloshing around some POR tank sealer and painting the outside.
Modified firewall welded as well. It will sit lower on the top crossbar, and still needs to be notched for the harnesses.
Its been mentioned a few times now that most front frame sections don't line up with the brackets. I used some flat washers equally on both sides as spacers, everything seems tight and square.
818 SRX - #91
Arrived 01/02/2014
Maybe I missed it somewhere, but what made you decide to go with the donor you picked? I admire your skills in getting everything to work! How many hours do you think you have into it to date? Any estimates on when you think you'll complete the build?
At first, I mounted the tabs that hold the front flexible brake lines to the outside of the frame - as shown in the manual and as you did. Later I discovered that an aluminum panel goes in the INSIDE of the frame so I had to cut a notch in the panel for the hard brake line - but that looked bad so I redid it all and re-mounted the metal tabs on the inside of the frame so the tab is on the panel with no extra hole. Let me know if you need a photo to show what I mean.
Well looks like you're a metalmaker. lolll
Nice job.
818 SRX - #91
Arrived 01/02/2014
The donor was for lack of options, just not many to choose from here. I also didn't want to pay for a wrx or sti as my plan is still to use an H6. I enjoy the fab work, a lot more than the rivets and bolts thats for sure.
I have no idea how many hours, and have no intention of counting them. I do a lot of what I like to call "figuring", ie; staring at the car and coming up with ideas, or how to fix mistakes. And there's a TV in the garage, so I'll often find myself standing up holding tools like a zombie with tunnel vision. Also my daughter takes advantage of me being in the garage, she sees it as me outside so shes able to go ride her bike which always involves me some how. So my # of hours spent in the garage is about 3x the hours spent actually doing focused work.
The car will be on the road first thing next spring, with any luck a month early just waiting on weather. I would like to go kart before snow this fall. I have yet to order an engine or ecu/harness, funds are being redirected into a money making project for now. So I'm going to start mounting the body before the engine, pretty sure I'll be the first to do so. Then I'll finish the bike project so I can have my work bench back. I'm enjoying the build, and would have to halfa$$ it to put it on the road this summer. But I plan to be testing/tuning at the first events/track days of 2015.
818 SRX - #91
Arrived 01/02/2014
Have you seen the 818 Registry on Google Maps?? https://www.google.com/maps/ms?msid=...a=0&dg=feature
Want your 818 added to the Registry? https://docs.google.com/forms/d/1zmF...rNCY4/viewform
Not having much success with my brakes. Have to vent so I can move on and get something productive done.
For the rear, there's no way to make a bracket off the old mounting holes. I could weld a bracket on, but it would only be my weld holding it there, and as confident/competent as I am, there's just too much cyclic loading and heating in that area. So I'll bite the bullet and pick up some WRX backing plates and modify the holes slightly to fit the pad perfectly on the rotor. According to to a forum, they're $50/each. While I'm at it, I might as well order some ARP wheel studs.
The front however we're supposed to be simple bolt on. I bought caliper brackets from KNS, and after weeks of searching (not intensely I might add) for Legacy GT 315mm x 30mm rotors I found some locally today. Bolted everything up, and the pad sits 8mm off the rotor. Now I read "online" that when using GTR calipers you need to use STI rotors which are 324mm. I also read "online" that the only aluminum Nissan 4 piston calipers were off the 300zx. So I'm assuming my calipers are off some JDM variant, as they do a lot of limited edition models we know nothing about. I'll do a search and make sure the brembo's are 324x30mm, and send an email to KNS for their feedback. Something tells me I won't find those rotors for $96/each....
I'll post a pic later, gotta get something accomplished before I head in.
818 SRX - #91
Arrived 01/02/2014
So here's the LGT 315mm rotors...
And the pad over hang I was talking about...
Quick google search and it seems '04 STI rotors are 326x30mm with 5x100 bolt pattern. I'm going to return the LGT rotors and begin the search for those.
Laid out some eastwood sound barrier and bolted in the gas tank so I could fit the firewall.
Need to install some rivnuts, notch for the harness', and do a final test fit with the seat before I can paint everything. Need to figure out a handbrake mount, tunnel, and will probably need to open up the slot above the tank later for wiring, etc. Not nearly as much done as I had hoped, but progress is progress...
818 SRX - #91
Arrived 01/02/2014
Are you happy with the layout on the rear section of the clutch line? I did it the was the book recommended, but I don't like it. I may buy more hard line and start over. Your routing looks solid, and should not get in the way.
TriguyDave
818 noobie builder
First start: Sept 28, 2014
Go-carted: Oct 4, 2014
Registered and Street legal Sept 30, 2015
Calgary, Alberta
818 SRX - #91
Arrived 01/02/2014
So no updates for over 6 months, wow, has it been that long? I finished fitting all the frame mounted aluminum and painted it in July, and all the panels are still in the boxes I brought them home in. A week before my last update I started my own contracting company and spent the next few months getting it going while staying at my last job. So 70hrs/week all summer. Now I'm down to 60/hrs a week with about 3hrs/day of commuting. I'm tired. I knew I'd have some free time during the holidays to get started back at it, so about a month ago I started pricing out engines. For the past year I've been set on a EZ36 with a AEM Infinity ECU, stock to start, but eventually turbo. I was nervous about the lack of aftermarket support, but was determined to be different.
Then the "rotary 818" thread was bumped up, and I hadn't seen it before. I've always had an interest in the rotary, and dreamed of owning a FD3S for a long time. I did enough research to determine that it "should" fit, found a jdm engine importer with a decent reputation, and ordered a 13B-REW.
Here it is upon arrival. Extremely clean for a 15-20 year old wankel. I'm not sure the year, the importer said its "a newer one with the 16bit ecu", but i've yet to confirm anything.
Lots of crap hanging off this thing. Lots to remove. The inner belt driving the alternator, water pump, and air pump was removed to gain access to the serial number as I required it for the receipt. Just in case its needed when registering it.
Removed the air pump (emissions), power steering, and A/C. I'll be ordering some pulley's, including a single belt crank pulley and a idler pulley to route the belt so the water pump gets enough belt around it. There's still lots to be removed, more emissions crap, and a bunch of vacuum lines. My eventual plan is to run a single twin scroll EFR turbo, however they're not cheap, so if the stock twins fit the chassis then I'll run them for now, at least until I know if the engine is in need of a rebuild. However, I had this little gem awaiting me when I pulled off the down pipe...
Oh joy. It was just laying there. The rear turbo seems fine, no shaft play, so I'll probably see if I can find a replacement on ebay. Not to sure how it broke, worst case is a apex seal broke and the debris got in the turbo. I will probably pull the entire manifold off and see what can been seen inside the housings. But for now it stays on, as fitting the engine and trans together and mounting it in the 818 are my priorities. This weekend I'll separate the mazda 5spd and start laying out a plan for an adapter plate.
818 SRX - #91
Arrived 01/02/2014
Can't wait to see this... love the rotary engine's revving ability. I hope it works out for you! I will be following this build for sure. Just please try not to wait 6 months between updates!
Tamra
First autocross 3/29/15
Very cool setup man, I like it very much
Nice job Adam, but 6 months that's too long.Though I understand 70h/week is a lot! You were still somewhat active on the forum so it's not that bad.
70h/week during summer is bad, as it's the only time to take advantage of the warmer weather (car driving, for instance). In Canada (and especially your north west for US people and mid west for us Canadians), what on earth can we do during winter besides watching hockey and building an 818? lolll
Good pioneer choice on the rotary, hopefully it'll fit better than my VR6.![]()
Very cool idea! Will you be starting a thread called "simplifying the 13B"??
That motor does look very clean, hopefully it's as nice on the inside as it is on the outside. Good luck on designing the adapter plate for the trans, that will be an interesting challenge. Not sure if you use CAD software but that might be a big help.
Thanks everyone.
There's so much info online, this engine was sold over 20 years ago. I'll answer any questions, and try to post as much detail as possible. But until I can make this all work, I won't bother with detailed threads on the 13b.
Not sure if I'm the right man for the job, but I'll give it a shot. If all else fails then I'll send it to the professionals. No CAD, a shop I do some work for just got a program called "Inventor" and will be getting a cnc mill, so once I have a prototype I may ask him to help me make a few more. I watched a video on YouTube about making an adapter for a toyota and it seemed simple enough.
This doesn't help me with the clutch/flywheel issues, but I found a interesting thread of a guy trying to make a AWD RX7 with the same combo. Unfortunately he stopped updating his thread. He goes into a lot of detail, and gives me a starting point. He concluded that the adapter would probably have to be 1" thick as the bell housing is so small on the subie trans. RE-Amemiya put a 3-rotor 20b mated to a 5mt in a Lotus Europa and his adapter appears to confirm this.
Spent a little time in the garage tonight, got home early. Managed to get the trans separated from the engine, no easy task if you take the brute approach. There's a "hidden" bolt tucked away below the starter housing. Then you get it off an inch, which is a small victory in itself, only to have to resort to the forums and find out if you remove a inspection plate and pry the "ring clip thingy" towards the engine it all releases and just slides off. Another one of those jobs that took 2hrs the first time and would take 2mins next time. I also stripped the back off the subie trans, and mounted the ffr plate. I realized the oem bolts are too long and they're must be supplied bolts in the pile of hardware on my workbench, one look at the workbench and I decided to call it a night. I need to get a 54mm socket on saturday to remove the mazda flywheel, so thats it for a few days.
818 SRX - #91
Arrived 01/02/2014
