Did anyone receive a set of high beam connectors in their package, I see the low beam but not high beam
Tony Nadalin
2018 SOVREN Big Bore Champion
2012 ICSCC ITE Class Champion
818R Build in progress
I had to buy them.
The high beam come from your donor, if you used a 2002-2003 donor, you have to buy them.
Tracked May 27/July 26, 2017
Build Completed Winter 2021
Did anyone have an issue with their high beam bulb fitting poorly? I can insert it and twist and it will not pull out directly but it is loose and does not fit in like the low beams did, tight. I know there is an o-ring on the bulb, but is there a larger o-ring that is in the light housing or something that I might be missing?
If someone could look at the Headlight where the bulb goes in, is there an o-ring, mine looks like there should be one that sits in the chromed plastic.LBHeadLight.JPG
I finally got back in town, and tightened the screws on the lock ring and it holds much better.
