![Midwest Classic Insurance](https://thefactoryfiveforum.com/attachment.php?attachmentid=40531&d=1428867682)
0
0
Registering the 818: Maryland
From http://www.mva.maryland.gov/about-mv...T.htm#kit_car:
How do I title a kit car?
A kit car consists of a body, steering system, frame, and related accessories intended for assembly with an excess or salvage engine, transmission drive line, rear suspension, rear axle and related accessories. A kit car has the outward appearance of a Historic or Street Rod vehicle (though it is not titled as such).
You can apply for a title in person at the Glen Burnie branch office. Typically, you will need to submit the following documents:
Proof of ownership – The ownership document must be for the vehicle frame used in building the kit car:
- If the frame is new (kits usually have a new frame included), the certificate of origin included with the kit is required.
- If the frame is from a used vehicle, a title for the vehicle in your name or a title that has been properly assigned to you is required.
- If the frame is from a salvaged vehicle, a salvage certificate in your name or a certificate that has been properly assigned to you is required.
Other documents that may establish ownership are:
- Registration document and bill of sale – ONLY if the state from which the frame was obtained did not issue a title (usually because of the vehicle’s age).
- Sales receipts
Application – You may use either:
- the back of the Maryland title, if applicable; or
- the Application for Certificate of Title to request the new title (and registration, if applicable). When the Maryland title is used as the application form, complete the section entitled Application for Title and Registration.
Proof of purchase price – You must submit the bills of sale and/or receipts for all parts and labor.
Odometer disclosure statement - You may use the manufacturer’s certificate of origin or the title to document the mileage of the vehicle. A separate odometer disclosure statement may also be submitted. Usually the mileage is “0” unless the frame was taken from a used/salvaged vehicle
Application for Assigned Vehicle Identification Number (if applicable) - A new vehicle identification number (VIN) may be assigned to the completed vehicle. The Maryland State Police will install the new VIN plate after they have inspected it.
Maryland safety inspection certificate - A safety inspection is required if the vehicle is being registered at the same time (most cases).
Your title will be mailed to you. If you also register the vehicle (most cases), your registration card, license plates and expiration date stickers can be provided immediately when you apply in person to the MVA; otherwise, these items also will be mailed to you.
![Martin's Dent and Collision Shop](https://www.factoryfive.com/wp-content/uploads/2019/02/martins-dent-shop.jpg)
