0
0
Originally Posted by
sponaugle
Congrats on getting it up and running!
I assume that the extra length on the STI front axles didn't cause any problems? I am just about to drop my transmission in and I'll be using those same axles with the stubs changed over.
Jeff, what's your plan for changing the stubs? You're planning on using a wrx 5 speed with sti axles right?
Research Calibrator
STiPWRD
I am using the STI axles with the STI Rear Stubs (outer), and STI Front Inner Stubs. I had my 5 speed converted to accept stubs by Andrewtech during the buildup.
Turn In Concepts
Looks about right to me, but without units on the boost plot and knowing what fuel is being used it's tough to say.
We had one on our dyno last week and really didn't see a huge increase in power over an AWD application. It was maybe 5% higher if i remember correctly.
Tony
The tune is based on 91 Octane from Safeway
Tony - Do you see an issue with dyno numbers for a RWD car performed on a 4WD Mustang Dyno?
sponaugle
Jeff - Yes, i used the STI axles as you described. I ended up adjusting my links so i have at least a 1/4" lateral travel in the axle to ensure there was no binding.
Research Calibrator
Kurk818
Awesome. Great to see your car making noise! I may have to come up and see it in person.
sponaugle
You are more than welcome to. Working on mounting the passenger seat in.
Im also going to attempt to install and integrate the STI center console. It looks very promising.
Tazio Nuvolari wannabe
I am not trying to insult anyone's intelligence. You asked.
An excerpt from this technical article by Stoptech:
Factors that will increase front bias |
Factors that will increase rear bias |
Increased front rotor diameter |
Increased rear rotor diameter |
Increased front brake pad coefficient of friction |
Increased rear brake pad coefficient of friction |
Increased front caliper piston diameter(s) |
Increased rear caliper piston diameter(s) |
Decreased rear rotor diameter |
Decreased front rotor diameter |
Decreased rear brake pad coefficient of friction |
Decreased front brake pad coefficient of friction |
Decreased rear caliper piston diameter(s) |
Decreased front caliper piston diameter(s) |
Lower center of gravity |
Higher center of gravity |
More weight on rear axle |
Less weight on rear axle |
Less weight on front axle |
More weight on front axle |
Less sticky tires (lower deceleration limit) |
More sticky tires (higher deceleration limit) |
Kurk818
I have no issues with it per se. The dyno could just be decoupled though to run just the rear.
Tony
